LarryH
did oliver ever build 880s without pto---also what makes a 880 jump out of high side n the trans -----it can take from 15 minutes to 30to jump out ---any help appreciated
The PTO was an option. You could also have a 1000 RPM PTO. Do you have a spur gear transmission or a helical gear transmission? I have more questions so I sent you an e-mail. Did you receive it?
This is a pic of a rear end on a 770 Oliver Lull lift. Just a small cover needed if you removed the PTO assembly.
