My O/U Drive slips in over drive. It seems ok in direct and under drive.
The input shaft is worn where it rides in the pilot bearing due to miss alignment of the PTO hub.
Can someone suggest where I could order this part (new or used) and probably the clutch plates, separator plates and specific bearings as may be required?
The input shaft and over drive clutches I know I will need are listed below, using Agco Part #'s.
30-3093042 Shaft And Gear - Input
165146A Plate - Clutch Separator
165147A Plate - Clutch Driven (Alternate 30-3214346)
I already have the complete reseal kit on hand for this unite.
All comments and advice on overhauling the O/U drive will be appreciated.
