Josh in Pa
I am working a super 88 gas. I have replaced manifolds and carburetor for other reasons, and have rebuilt engine. Starts easy and runs good at idle or full speed. But I cannot get the governor right and it's driving me nuts. I&t manual is a little confusing, but with throttle full open, and governor arm pulled all the way rearward, I have adjusted the linkage to the carb to be 1/16 too long, so there is some over travel. The problem is that when its adjusted like this, the throttle lever "bottoms out" 3-4 notches away from the bottom notch. The only way I see to fix this is adjust the rod between throttle lever and governor. I haven't tried this yet because the manual says this adjustment is for high idle, which is exactly where it should be now. What am I overlooking?
Josh
Josh
