2-44 transmission
I just picked up a white 2-44LL. It does not have a shuttle transmission. Does anyone have any production numbers? It seems to be speced out oddly. Thanks
As far as I know, the 2-44LL was an industrial 550 with a loader. So there should be production numbers for the industrial 550. It likely also has power steering.
   The tractors were built as the ordering dealer specified as long as it was an approved change.   Apparently the ordering dealer specified your tractor with build codes [b:654c4848f0]E[/b:654c4848f0] 41 PTO, [b:654c4848f0]F[/b:654c4848f0] 61 Hydraulic system less remote valve & [b:654c4848f0]P[/b:654c4848f0] 49 3 Pt. arms and related components.
   Remember, the build card shows how it was assembled.   A dealer or someone else could have added the Hydraulic system, PTO and 3 Pt. arms later.   The last year of production was 1976, a lot of things could have happened since then.
(quoted from post at 17:41:52 11/16/16) I just picked up a white 2-44LL. It does not have a shuttle transmission. Does anyone have any production numbers? It seems to be speced out oddly. Thanks
Mine has 3 pt and PTO As someone mentioned you could order them anyway you want I've seen Yellow ones and Green ones and Once a Red one
