0liver 70 governor
beck55
I need new flyball bearings for my oliver 70 governor. Does anyone out there know of a good source? I've googled and cannot find anyone that sells them. I would prefer NOS but would be happy with a good set of used. Also, can these be replaced by removing the front housing of the governor or does the whole damned thing need to be disassembled? Thanks!
J-Thanks for your reply. I think I jumped the gun on the problem. I have a 3 gear model. Today I pulled the front casing off the governor and found that it doesn't have the fly wheel bearings. It's a fly weight design. I just assumed, based on other posts, that I had a bearing problem. As it turns out, a small spring on the adjusting bolt had broken off. I replaced the spring and it runs perfectly. Again, thanks for your post.
