oliver 550 tsx 811 775 carb throttle bore?
Can anyone verify throttle bore dimension on a Oliver 550 marvel tsx 811 &/or 775 carb. The manual I have states that its 1.09 bore it just does not seem right I don't have a carb to verify and does not seem it lines up with other marvel carbs unless its an oddball sized Marvell carb.
Nothing odd about the body, But... the main jet is an odd ball
Not the same as what you find in the Deere carb.
But you can make them work
