Wiring question
oliverkid
Working on this 4-150 and the poor wiring harness is all jacked up. Thats really the worst part of the tractor is the electrical system right now. Anyway trying to fix some broken wires I found and there is one that is labeled a resistance wire in the diagram, goes to the rectifier lug on the alternator. Problem is the wiring diagram doesnt call out the original color of the wire, and the biggest issue is that it doesnt say where the wire comes out in the dash on the other end. I tried to trace it but I cant contort myself up under that dash very well to see. Wire appears to have a black jacket and the wire is only a single strand, or at least thats what it is at the break.
Hey i figured this is probably the only way to talk to you now, but I want to thank you for your amazing videos and time and effort. I learned a Lot from you and your videos. Know matter what people say about your equipment, its still the best. I wish you the best of luck with the rest of your harvest. Hope to see you maybe in the future, cause if the ground will dry out I want to see the ripper on the of 4-150:)Medow green forever.(or gray)
StrongsOlivers
