Mark in Minn.
I have a 1650 with a pto that will not stop turning. I adjusted it so it should not turn with anytype of pressure on it but you cannot stop it with even a 2x4 against it. I took it apart and everything seems fine except for 2 driven steel plates have a small warp to them when you put a straight edge to them.
Is this my problem or could it be something else. Also how do I tell for sure which pto I have 540 or dual speed. It only has 4 of one plate and 5 of the other which would indicate a dual speed instead of 5 of one and 6 0f the other. Serial number indicates a late 1969 with a 3 speed transmission. i have both shafts (upper and lower) out but can't see how a dual speed would be driven. Not sure what to look for.
Any help would be appreciated.
My phone number is 507-475-0200 if anyone whats to call with advice.
