I have a White 2-44 with a loader and shuttle shift transmission. The radiator is leaking so I've pulled off the loader and opened everything up to get it fixed. I've noticed a lack of power so I ran a leak down test and was 30-40% leakage on each cylinder and all the leakage was through the rings to the oil pan.
The clutch has been slipping for a while so I'm afraid I my need to split the tractor to put in a new clutch. The clutch gets a lot of use with the shuttle shift and loader work.
Is it time to order a full engine rebuild kit or is it just rings and hone the cylinders?
If I have to split the tractor for the clutch is there anything else to do while it is split?
Thanks,
Thanks,
