1450 oliver value and reliability
deene
I know there have been lots of comments about the 1365 being good machines what about the 1450's..i know where ones at with fwa good rubber they say it runs well..decent sheetmetal for about $4500.00 is this in the ballpark?..thanks for any replies
thanks rrlund i was hoping you would reply and let me know the scoop..thanks again and have a good evening
Where are you located? We sold several of the 2 wheel drive models and I think 2 are left in the area> They were very reliable!
We had 2 of them back in the 80's. Very decent tractors. Just hard to get parts for even then. 4wd, I have never seen one. Would be quite rare. The co-op federe in Quebec was the best place to get parts at the time. Ours would pull the 3 -16 mounted plow all day long. Did a lot of work with the both of them. Way better then the 411R we also had.
I have a 1465 4WD it runs good and is an interesting piece of Oliver/Fiat history but its not a tractor I would want to use as an every day worker.I gave $1000 for mine,it needed a steering
box and I had one as I have 2 1450 parts tractors.Also have 2 1365 models a 4WD and a 2WD if you want a tractor to use look for a 1365.Also the 1465 is a pretty good tractor I use mine for things like pulling my 10ft brush hog good solid 70HP tractor.
I did some work on one for a neighbor. I knew that I was in trouble when one of the people at the dealership wished me "good luck". Parts are hard to find. I have read about, but not experienced the problem with broken head bolts. I am no longer willing to be around one of them.
