1600 timing???
Working on a 1600 gas, it had a full tune up and carb rebuild was running through the summer great. Fired it up brought it out of shed then it all of a sudden started to load up, slobber and die. Will not start now. it has fire and I put a good running carb off another tractor on and still nothing. Are these tractor known to jump time or any other thoughts are appreciated. Thanks Mike
The distributor is run off the oil pump, don't see how it could jump time. It only goes in one way as well.
Donovan from Wisconsin
Bad points and/or condenser can make the spark erratic, sparking when manually checking the coil, but not consistent enough to run the engine. Otherwise, I would think it would be something internal, such as valve clearance.
