550Doug
- Location
- Southern Ontario
I have a 2-44LL that has a loader on it. I believe that the loader is a 1588 but I suppose it could be a 1610, how do I tell the difference? What I need is a new screen that is on the hyd tank outlet that goes to the front mounted hyd pump. If I could get a part number for it I could try my local Agco dealer.
The screen is basically a 3 inch long wire compression spring that is covered in mesh screening on one end and the sides. This is mounted inside the screw-in outlet adapter.
