Unusual 6 bolt rear hub on Oliver 60
mzoerner
New User
I am looking for a 6 bolt rear hub to fit the splinned axle of a 1941 Oliver 60 row crop.
The 6 bolt hub has a casting number of HA704B, the 9 bolt rear hub has a casting number of H704B.
I am not sure if the 6 bolt hub is original to this tractor or from another model.
Does anyone have any suggestions?
Instead of saying it is a 1941 model 60 tell us the serial number as there were several different hubs used on the rowcrop tractor. Also sure looks like it was on cut-down steel wheels.
look real close at the outside of hub. Someone has turned them down in lathe and redrilled the 6 bolt F20 pattern. They did a nice job.
Well it is a late 41 and would take the second of 3 hubs. The first 70 tractors used a different hub, tractors after the war also used a different hub. Where are you located?
