White Oliver Loader Backhoe 2-62-16
Rotcpain
New User
I just picked it up for 3k. It is blowing a lot of white smoke. I checked the temp at the exhaust manifold and the 1st and second from front to back are 40 degrees cooler than the others. I will do a compression test when I have more time. How do I go about making sure I order the right parts to repair the engine once I open it up and see what I need to replace? Where do I find injectors?
This is my first piece of equipment and old one at that.
Thank you,
Lewis
Well since you have a problem with two cylinders in a row you might want to think headgasket. Also another item to check is remove the valve cover and check valve clearances. It may have stuck exhaust valves. Post the serial number of the tractor as well.
Model:1550, S/N:455-72038/215367
Engine #'s: 185320/160918A/19194
Loader S/N: 12684, Model:1678
I was furnished a receipt from a company the last owner had the engine rebuilt in May of 2008. Maybe because the muffler i
So I found the problem!
Rings are probably worn.
