Harryaroo
I found a Oliver 70 that needs an engine-- Is it possible to put a larger engine in this tractor? I would like to put something in it that might get me to around 50 hp-- any suggestions ona relatively easy fit?
I don't know what it would be for an easy swap. Those had a Continental engine instead of a Waukesha like the Fleetlines and Supers.
Probably not if you're talking "easy fit". I bought one with a Chevy engine in it,but they took some large channel iron and built a whole new frame for it.
They are a 201 cubic inch engine, I always thought if you balance it a bit better and plane the head and finally crank up the rpm 50 hp I'm sure is achievable.
