1950t pto ?
Benelli
I am working on a few leaks on a 1950t that are on the pto and 3pt lift arms. I am pretty sure I can get the 3pt seals fixed. The pto is what I am wandering about. It is a dual speed unit. Where are the seals that need to be changed located at in the pto unit? I assume some orings and a seal or 2 . Thanks for any help
There is a seal in the bearing cap on both the top bearing cap and also the bottom bearing cap. The 2 seal are the same. East of the bearing caps is sealed to the housing with an O-ring. They can be changed without removing the unit from the tractor. Hope that helps. More questions?
