White 2-105 engine replacement
1070BK
Looking at a 2-105 with a bad engine. I have a Perkins 372 out of a Massey combine that I've
been wanting to put in something. I've seen on here a 1850 with the transplant. Just wondering if
it is possible on the White.
A 372 is a 354 with a larger bore (thinner sleeves) Does the 2-105 have a dot 1 or a dot 4 engine? The 2-105 is turbocharged, the 372 is not and was strictly used in combines and was not turbocharged. If you go that route, don't throw the 354 away because it will take parts from it to complete the project. My 2 cents worth. J.
It is an earlier 105. I haven't been able to look at it other than photos. I will assume at this time that it is a dot1. Would that make it easier?
Should go in there fairly easy. I got one in an 1850 with a turbo. Check the bolt pattern on the intake and exhaust manifold I ran in to trouble with that on swapping Perkins in a 2-85. I had to drill some new holes. Everything interchanges between a 354 and a 372 just different bore.
The manifold bolt pattern on the combines and 1850 are the same,the 2-85 and 105 are different. Diagonal pattern vs horizontal.
