D13series2
Since you missed that big Ollie, mebbe you should stop by and get all my equipment. I don't think the 1250 can pull the 12' 251 disc (my 430 case will move it but not pull it in the clay) but it'd look nice in front of the 5 bar hay rake.
Does it have a 3 point? Would it work with a 2 bottom? Because I still haven't figured out how to make that work with the Case (tractor wheels can't be set in quite enough unless I pull off the hydraulic levers..)
