hey Rlund, mebbe you should buy mine. LOL
Since you missed that big Ollie, mebbe you should stop by and get all my equipment. I don't think the 1250 can pull the 12' 251 disc (my 430 case will move it but not pull it in the clay) but it'd look nice in front of the 5 bar hay rake.
Does it have a 3 point? Would it work with a 2 bottom? Because I still haven't figured out how to make that work with the Case (tractor wheels can't be set in quite enough unless I pull off the hydraulic levers..)
Well, just for giggles, I hooked the 251 to the back of my 430 case. It pulled it thru the weeds OK, snorted pretty good when it hit some raw dirt or on corners where it cut deeper. Good thing is the 10 minutes of serious work got rid of my wet stacking issue!
