blank cast date on engine block
Kell
bought a '74 1955 project. per subject, cast date on the block is blank. is this a factory replacement block? mistake? or why would it be blank? aside from someone grinding it off intentionally - pretty clean removal if this is the case.
Is the Waukesha and Oliver casting number there? Is this a block with a revised lube circuit? You have a phone number?
