I cut a 4 bottom white 508 plow to make a 3 bottom. I am repainting it. Was wondering what is the closest color or brand of paint
to match from that era?
Hi Larry, is this the same one you use for our plow days? If you want to paint it red again is should be called Sumac Red or also called Combine Red and the white for tail/furrow wheel is Bossline White. It has been available thru Agco and made by Valspar same as JD & CIH. I can look in one of my White plow manuals and double check the color for you. Otherwise you can paint it Meadow Green/Clover White to match your Ollies.
Brad
