oliver 1650 draw bar fix pic
jim_uny
had manure spreader on & went across entrance to field (non-level) and it broke. put wood block between left tire and left bracket. put hydaulic bottle jack between both brackets to make them parallel. ground and welded. added l channel. when stock comes in i will re-inforce above drawbar bottom piece. i see that factory did it on latter model 1650.
oops here is pic
My 1550 had been welded like that when I got it. It broke a few more times. I finally put one off a parts 1600 on it.
