1550 RC rear axle seal surface
OC4-3D
I actually started re-assembling the 1550 RC yesterday. Just a few more parts to sandblast and paint. The job for today is replacing the bearings on the rear axles. When I removed the old bearings, the shaft got scored up a bit.
Now I'm concerned that the seals will leak. Anybody feel like giving some free advice? lol
Chuck
After you put on the new bearing install a speedy sleeve where the seal runs. They are a thin stainless steel sleeve that provides a new surface for the seal to run on. Any bearing supply place should have them. Give them the seal number and they should be able to fix you up.
