I've removed the over/under drive and clutch pressure plate. It doesn't looked scored or ridged. The flywheel has what appears to be minor cracks on the pressure surface.
What I was wondering does anyone have the measurements for the thickness of the pads on a new driven disk? It would be easy to measure with a caliper and compare to a new one. They look decent but just wondered if I should be replacing parts in this area.
The throw out bearing seems to be free and smooth spinning but might be wise to replace it since everything is apart. The sleeve slides smoothly on the support tube no side play or wear showing.
Thanks for your advice in advance
