My balls do not fit
Hoboy
I have a 1650 that I needed the lift arm balls for. I got some different ones that were from Agco that was a part number 105967A and they do not fit. The outside diameter is about 1/4 inch too big. So I tried some aftermarket ones and the same thing. I looked in the book and they do not show me a different one. So what gives? As far as I can tell these are the original arms.
I got the correct ones from Tim Smith in Ohio (330) 832-9792. Made the same mistake first time got the wrong ones from AGCO.
If you want a pair that holds up pulling a plow or any other 3 point implement, instead of turning to mush like the ones AGCO or any where else sells,
I have some that Imade up. Hardened just like the originals, and actually hold up. Only reason you'd need another set is so you can leave them on both the plow and the cultivator.
2"OD cat. 2, and I use them in our 1600 & 1855.
Donovan from Wisconsin
Deere CatII top link balls are the same. I bought some at Farm and Fleet one time for a Ford thinking they were the same,but they were too big.
I don't know. I've got a pair of CatII here that I got way back when there was a Deere dealer around here. That's where they came from.
Where are located in Wisconsin and how much are they. I live close to Dale/Appleton. Or call 92o- 284-o5o1 and leave message.
I live in Hilbert, family farm is in kaukauna, and I work in Appleton, so we're not far away. You can call me at 9 twoO, 858 211 six.
