Cockshutt starter
Dennis P
I am not for sure which model this is that I am working on. I would guess it is a 30 with overhead valves. Where is the data plate located? I also need brushes for the Autolite Max 4081-7C starter. The brushes have Autolite 1-N MAW-13 stamped on them. Where could I find brushes? I am a MM guy & this is the first Cockshutt that I have ever worked on. Thanks!
serial number is probably stamped in top of left frame rail. model 20 used 24 inch rear wheels, larger models used 38 inch wheels, models 20&30 are 4 cylinder, models 40 & 50 are 6 cylinder. these are some quick ways to identify coop and cockshutt tractors. more info @ tractor data dot com and international cockshutt club. I hope all is correct and helps. leroy
