Todd Hertel
New User
My neighbor has a Cockshutt 40 that had the engine replaced with a AC G262 combine engine some years back. It recently had to be torn apart due to an oil pump failure. Upon inspection of his engine, I see that the numbers on the rod caps are facing the cam. I don't have an AC manual but have a cockshutt/buda manual which states that the rod cap numbers are to face opposite to the cam side. Which orientation is correct "numbers face" or "numbers opposite" to cam. What are the results if incorrect? The oil pump has 2 cast tangs around the intake to keep the screen away from the intake. One of the tangs broke off and jammed the gears in his pump. It spun the pressed gear off the end and pushed the distributor up. We are also looking for a good used oil pump for a G262 AC engine. Any help would be greatly appreciated.
Thanks
Todd
Thanks
Todd
