1963 Oliver 550
I'll neglect the back story here...
Removing the transmission cover I discovered the 1041 and 1045 shift couplers will not move. the 1023 gear also has a few missing teeth.
Am I destined to split the tractor? Or is there a way go in through the right side of the tractor, to move the differential enough to get the pinion gear out? So I might remove that portion of the gear assembly, and make some repairs?
