Hyd. remote
hoghollow
1965 Oliver 1650. The left side remote will leak down (allow tailgate to open on round
baler) Switched tailgate to right side remotes and left side to hyd twine tie. The problem
followed to the twine tie. Assume I have a problem with left side remote valve. Is valve hard
to rebuild? Also what to look for I assume you pull top cover off and valves are located
there. Ordered I.T. manual but do not have it yet. Any help would be appreciated
Jon I checked both bleed screws the one on left side of tractor was out about one full turn the right hand side was snug. Will try remotes on baler in next couple of days. Sure would be an easy fix. Fingers are crossed THANK YOU SIR
