Thanks for the replys. Turns out the bent rods are intakes. All were straight at overhaul. I always thought the clearances would tighten as the
new valves seat in. Tractor runs perfect after setting valve clearance then after a few hours it starts cold on only 2-3 cylinders, warms to running
normal. It don't act like guides are binding. Only 19+ hours since overhaul 5 years ago. Don't get much use, but useful when I need it.
