1650 PTO seal
88 Diesel
To change the PTO output shaft seal on a 1650 does it have to be removed from the backside, by removing the
PTO unit and gear train to gain access? Thanks in advance.
Since it leaks odds are you have a single speed PTO so the oil needs to be drained from the rear end. Do you have a seal puller? Do you need a picture?
