Remotes are very slow raising implements, some times it don't even wants to lower them
hydr oil is getting too hot.
The screw of the relief valve on the pump has to be screwed in nearly all the way to get the pressure at the remotes to read 2250 psi,...the pump starts squealing if i raise the pressure even more
The compensator and unloader valve block under the pump has been taken apart and there appears nothing wrong with it.
The hydr filter is new and the tank is clean.
Pump shot?..or am i missing something ?.
I have no flow rator nor have i access to one.
thanks
thanks
