MetalMasters
New User
Hi guys, first tractor not sure how the power steering works. 60ish Cockshutt 550 diesel with a wide front end. When I am parked I can turn the steering wheel 1/2 turn without the wheels turning. Seems like a bit too much slop. I only Drove it once so far, bought it a mile down the road and drove it home. The front wheels would be fine then all of a sudden they would start shaking back and forth and then stop every so often it happened again... not sure where to begin fixing this issue..... also I noticed the left front outer tie rod has been replaced/welded to a longer shaft but it doesn't stick out as far as the right side. So the alignment cannot be true.... I am ordering a replacement soon....
