Type A fluid for 1650 Over/Under
matthies
What type oil is used if I can't find Type A? Did a little search here on yt and didn't find much. Dextron, Mercon, Type FA, or ? thanks chris
Dexron or Dex/Merc combo. I had one that barely worked,kept kicking in to under drive for no reason. I went to the Dex/Merc in that one and it cured it.
I had trouble finding type F locally and ended up buying a case on-line from Pepboys. Might be worth a try for type A.
