Opinions....Oliver 1365
Neighbours looking at a Oliver 1365, 3pt hitch doesn't work, besides having that fixed, anything to watch out for on these tractors? It's going to be lightly used for a acreage. Looks just perfect size for the job.
I run two a 2WD and a 4WD both are good handy tractors in my opinion,parts can be had from several different companies and many on ebay.Most of the parts on a Long 550 or 560 will work on the 1365.The smaller 3 cylinder Fiats are the same tractor as the 4 cylinders really except 1 cyl less.As far as the hydraulic lift not working it most likely has a clogged filter intake screen which is easy to take off and clean.any water in the oil in the rear it'll need to come out and new added for the hydraulics to work right.
Excellent tractor. My only complaints are minor. They could use another in between reverse. The two that they have are either real fast of real slow. Maybe it's just mine,but my remotes are kind of slow. The 3pt is fine and mine has the auxiliary pump for the loader.
Check the link for more recommendations.
Import tractor buyers guide
