Single acting cylinder on 1650
Johnnie T
I am looking at some 12' batwing shredders for my 1650 all have single acting cylinders. I have a operators manual but still not sure I could
operate 2 cylinders one per remote.if some one has hooked up some to the 50 series I would really appreciate a run down on how to hook
them up. thanks in advance Johnnie
I am not sure. either remote will operate a one way cylinder. I have several machines that take a single acting to lift, and double acting for swing. Those I have to hook the lift to the right and the swing to the left set of remotes or weird things happen. I kind of don't think two single acting cylinders would work. I have never adjusted te interlock screws that the manual talks about, because I switch back and forth between implements so often. Maybe that would help.
Josh
