Hello new here, seen a old post. Too old
to post back to. Now, lift was working
fine. Shut tractor down. Lift does not
leak down. Fired it back up, lift worked
up and down just fine. No noises, no
jerks,smooth as silk. Pulled lever up
one last time, lift went north. Tractor
engine bogged when lift got to the end
of its travel. Engine is still in strain
from I'm assuming pump,pumping against a
relief valve. Pump housing got hot,
where fluid passages from pump go
through housing. Any ideas on problem? I
will post back when I find the problem.
I will not leave anyone else hanging
that is having the same problem.
Oh,,,,no implement was on lift at either
time. Thanx for any replies.
