Farmall H rim fit S88??
old
Ok so I have a spare rim and tire of a Farmall H and have a flat on the S88. So will the clamp on Farmall rim clamp onto the cast center of the S88??
Thanks
Thanks but I did already figure it out after I did some brush hogging to be able to get the the tire and rim. Some how weeds that are 6 foot tall make it hard to see what a rim looks like. Right now I am wishing that tire was on a JD rim I have off a JD60 because it looks like it would work on the S88
Ya,the JD number series will fit. The letter series won't. I have a Deere rim on my 1550 and an IH rim on my 1600.
I may even look the JD rim over a bit more and mount the tire form the Oliver rim on it since the Oliver rim has a pretty good size hole in it that I have started to patch but the JD rim if in better shape maybe the better way to go with the least amount of work and when it is 95 plus with a heat index of 105 plus doing he simple thing seems to be the smart thing
Well I got the JD rim on just to have it fall off after I got 1 bale almost done. I do not like the JD 8 dimple rim since the first time I put it on I guess I did not get the dimples in the right place to the rim almost fell off. Got it back on and the locks centered in the dimples this time so think it is going to work out just fine
