1365 Oliver
55a
A friend of mine has a Oliver 1365, he says around 70 something model. He wants to service the hydrolic system. The question he has is there
a filter in the housing somewhere for the system if so where is it located ?
Thanks for any information
JG
On the starter side there is a tube that has a filter in it. Look directly under the starter you see the pipe that turns up into the horizontal tube that's where the filter is housed.
The filter is located on the right hand side of the tractor next to the engine. It's located in the large steel hydraulic line that runs from the hydraulic pump that's mounted on the front right side of the tractor. The filter is in the spot where the line gets much larger for about a foot.
