white 2-105 internal hydraulic leak
I have an internal hydraulic leak on my white 2-105, hydraulic pan is fine checked that it is going into the transmission at a pretty steady pace lost about 5 gallons in about 10 min how else can the fluid go into the tranny
Thanks
Like Lee said the thing to do first is remove and plug the two lines going to the pto valve. But if that doesn't stop it the leak could be coming from a seal inside the cooler pump which is located inside the rearend housing. This pump can be accessed by removing the main hydraulic pump and then removing 4 bolts and lines and pulling it out of the housing.
