When I have the pto out of gear (the handle all the way to the back) and I lift the 3 point all the way up, the arm comes in contact with the pto lever and pushes it forward enough to slightly engage the pto. I know if I don't lift it all the way it wont hit but that is difficult to do as the rpm are pretty high to make the 3 point work. Even if I stop it short of coming into contact it will ultimately work it way up enough to make the pto spin. I can put a stop on the lift control handle that might work but I'd really like to be able to lift the 3 point as high as possible which I understand maybe just before it touches but I'd guess that Oliver had it figured so that you could lift all the way and not hit the pto lever if everything was right. It's nice to be able to lift the Haybob up and over a windrow. Anyone have an easy solution?
