Oliver super 99 thermostat
duane o.
Hi everyone I am looking for a thermostat for an Oliver diesel 302 cid from the super 99 or 950 any leads to a new one would be great. Thanks
Duane o.
Question for you. I have looked at more 195 Waukesha engines in cranes than in Oliver tractors, but how close is the Super 99 thermostat to a thermostat used on the later Oliver's starting in 1960 with the 1800 tractors?
I'm not sure. I have been putting off taking it apart as there are no leaks and parts to put it together again. Being I've exhausted most avenues except under the Waukesha links I'm going to resort to taking it apart and checking other models.
I could have a look for you next week when I'm off work, I'm sure there are several laying around I could compare to.
Hi Napa has the thermostat for the 302 diesel 99's . The part number is TH 55 for the 160 F degree and TH 155 for the 180 F degree thermostat. Carquest has them also and the numbers are 30026 and 30028 . It also fits alot of other tractors and trucks so advance auto or o'reillys auto and maybe even autozone could cross the Napa or Carquest numbers . If not i can get what trucks use the same thermostat and list them for you just let me know . They could also take the old number off your thermostat and cross it to get you one .
Thanks for the info. My Napa crossed the carquest number. The Napa numbers from the states don't cross up here in Canada. Picked one up gonna see if it works this weekend. Will keep you posted. Thanks again. Duane.o.
So I got that thermostat out to the farm and took the super 99 Oliver diesel apart. This thermostat is not even close to the correct size. It's at least 3"or more in diameter. I picked up one for a 62 1800 diesel it's 3.25 in diameter. Hopefully it works as the original is stuck open. Will post an update when I get back out there.
Just an update: I found that the thermostat from the 1961 1800 diesel fits the super 99 302 cubic inch gas and diesel.- Oliver 950 gas and diesels. Excluding the gm diesel.the ones listed below are for something very small. 880 maybe.
