I need to replace/repair the water pump on 2-70 diesel, it is wobbling and leaking. I figure the 3 options are: 1. purchase reman water pump, 2. Purchase "new" water pump, but that would probably be Chinese, South American etc. or 3. attempt to rebuild with kit for bearing, seal etc.
I am inclined to go with option 1, rebuilt that has same casting number as mine, probably spend $100-$150. What do you all think, is that the best route? Any suggestions for an online source or dealer I can call on phone? Also, does the pulley usually press off/on easily or is there potential for breaking or bending something. Thanks for advice, the seal let loose suddenly after I had just filled 3-pt tank with 150 gallon of herbicide; had to fill rad with fresh water and quickly run out the spray.
