88 Rear Axle Bearing
super99
I think I have a bearing going out on the rear axle on my 88. When driving, it makes a noise. I jacked the wheel up and spun the wheel by hand and I don't hear or feel anything unusual, What am I missing? Chris
Hi Chris: Jack it up and let it down quickly. See if the axle has end play when the tire hits the ground. Does the wheel have wheel weights? If so, are they tight? How about the hub U-bolts and have you checked to see is properly secured to the center section. Also remember an 88 an a super 88 take different bearings. J.
