2-105 LOWER FUEL TANK
OLWHDA
The mounting rubber bushings are worn out and the tanks are full. Proper procedure for replacing the bushings would be a great help. Do you block the tank up chained to frame so you can remove the front step framework, or just screw the bolt out and install new bushings, I'm open for ideas, old tractor is a 1975 model if that makes any difference, and AGCO must be proud of them for the price of new bushings and washers.
