60 Pulley with Adjusting Flange
60 Fan
Working on Lower Adjustable Front Pulley(s) (HS-370). Freeing Up and replacing bolts etc. Looking for washer, fan pulley lock screw (C-348) which is essentially a small washer with an extended curved tab. Or a suggestion as to a replacement item other than a common flat washer. Need 3-4 if available. Any help appreciated.
