Oliver 1650 over under
Benelli
Hello, I have a late 1650 direct injection over under tractor. The engine runs great. The 3 speed is where I am having trouble. Over drive works great. Direct seems to be slipping or not shifting properly. Under shifts but fells strange like it take a bit to shift. I just put a new clutch and pressure plate in the tractor it was bad when I got it. Any ideas what going on in the 3 speed? Thanks
O. K. Direct drive and overdrive are both engaged by hydraulic pressure. You should take a pressure check and in each range. Also do you know the history of the tractor? I left the dealership in 1976 and there were changes in the shafts and clutches. Since this is 40 years later I am sure that parts were changed since I have left. I have also in my time back then seen some clutch plates where the teeth on the plates wore off. Check the pressures first!
