Got a busted tachometer cable on Oliver 1800. I thought this would be an easy fix. I robbed the cable off our 1755 parts
tractor and it will not fit into the connection port of the 1800 tach. After measuring the bellows on each cable, they
both measure different diameters. The 1755 cable will not fit onto the 1800 tach connection because it is smaller
diameter than the 1800 tachometer connection.....Now, (hence the problem) I go to order new cable from this site, and
the new cable description says it will fit 1755, 1800....I'm puzzled, because I just robbed the cable off our parts
tractor which will not fit, but the new cable description says it will fit either 1755/1800 tractor....anybody run into
this before?
this before?
