Part Time Pete
- Location
- Leatherstocking Region NY
Mr. Schweibert - did you get a chance to see if a 1650 rocker arm shaft will work on a 1755?
I got the sleeves out of it - found one with bad o-rings and badly cavitated, and another one with with a broken ring. I think maybe I should just put a sleeve kit in it. The main and rod bearings are showing some wear - not sure if it was from the coolant in the oil. I'll replace them too
Thanks
Pete
Thanks
Pete
