Married2Allis
I recently changed the 1650D 2-speed fluid and put in Dextron III ATF -- I over filled it and forgot to correct it (note to self ;->. Brush-hogged for a few hours or so and was in direct drive the whole time. Afterward remembered that I had over filled it, so I went to drain the excess ATF and it was emulsified - 100% milky like a rasberry smoothie. I drained the antifreeze out last month and have been running soft water only with a flushing agent to clean out the cooling system. Does this mean the heat exchanger is leaking water into the hydrapower? Did overfilling the ATF cause this? - thanks.
